Android 12 update
Same here, Pray for us ladies and gentlemen.
As others have mentioned, I don't see much different. The charging notification has a different look, you've got the ability to color scheme your icons, but annoyingly, they appear to only work on Samsung app icons. I did see an "extra dim" toggle for my task bar, which I'm kinda excited about.
I'll have to check one of the videos from Google which shows off Android 12 to even notice what the update was all about.
I can say that my phone seems to be working perfectly (knock on wood) after the update.
Nothing yet on unlocked Verizon. It's a subtle update from Android 11 if I remember correctly from my S22U that I traded in a month ago for the Fold 3.
So to all who've received this update/upgrade: if you use you Good Lock, would you check if modules work? Which ones, etc? (Doubtful, though I can muse) Thanks! Have a Happy New Year. May all your 2022 wishes manifest!✌
Multistar and Navstar are the only 2 that are waiting for an update.
So far I've noticed is that the notifications are not separated into silent and normal anymore... unless there is a setting that I haven't looked at. I liked the separation.. It allowed me to prioritize certain notifications over ones that are not urgent.
(ATT ver.)
(ATT ver.)
Where in notification panel?
When you dragged down the notification panel to see your notifications, they would be separated by regular notifications and then "silent" ones grouped below those, and those notifications show up without any sound, etc. You could choose which notifications could be "silent". The ability to do that seems to be gone and all the notifications are all together again.
Yeah don't see that
Probably a week or so from my experience sometimes couple days .
I guess I missed the beta. I don't really care that much about updates especially system updates. They get here in a decent time so there is no use stressing over it.
Yeah , waiting for public release which Samsung beta Moderator mention target rollout Dec 30 for unlocked
I'm running an unlocked Fold on Verizon and I haven't seen an update yet. Still just curious if the update will unlock the esim.
Yeah same here unlocked Att , the whole beta it didn't have esim but they mentioned in public release it would
Annuji202
