Android 17 Beta
Alright I couldn't deal with not being able to use my phone anymore. I was missing too many important text messages and phone calls. Had to do a factory reset.
What I didn't know was I would still be on the beta. Well, it's all working now. Just have to re-sign into all my apps and stuff. For some reason there was no backup of my SMS messages, only MMS.
Lastly, most importantly, make sure you have a device you can get a passkey from. I had to dig out my old pixel 5 and get it charged so I could log back into the phone.
I would have done the same when too many things are crashing that's why I mentioned factory reset which I know everyone hates or wait for the next beta build.
Let us know how it goes.
Well because I'm on a newer build than beta it won't allow me from setting or side loaded because it thinks it's a downgrade, which means I will have to factory reset if I want it or if beta 2 comes out before the next stable build
Reactions: Laura Knotek
I installed the Android 17 Beta 1 on my Pixel 10 Pro XL had a few hiccups but seems to be doing OK. I did notice my text messages did not carry over from the backup I did before doing the device wipe. Anyone know how to find these messages? I've tried a few things I found on Reddit but no luck.
This is why I use sms backup and restore. I never have to worry about that. Good luck
You did a back up before going to beta?
Sometimes it takes 24 hours to repopulate or you can try resetting the app by clearing its data then force stop it.
Reactions: Bkdodger1
Yea I think it was back in around my Note7 days. I loved that phone until they disabled it
Same. I really loved that phone. Mine gave me ZERO problems, but it got nerfed to the point where it had to be returned.
how do you get the beta? i looked in system updates dont see it..edit nevermind how is it? is it worth trying or 2 buggy still?
says im opted in but i see no beta update?
You might be on a current public build that's higher than beta build which means u have to wait for next beta build and check for software update. This what happened to me .
nivea531
