- Feb 6, 2017
- 99,140
- 15,858
- 113
I hate you have to eraseYeah I did that too
It is what it is. I'd prefer not to, but I'm not one to make a huge fuss over it.I hate you have to erase
Yeah hopefully. That happened to me every time I looked at the screen it seemed. But with me the wifi toggle when I looked was already toggled off. It had exhausted the search for wifi and disabled it. I would turn it back on and it was a crap shoot whether it found any or not. Sometimes I had to reboot the phone to find any again. A reset of my network settings didn't help, factory reset only helped for a short while then it started all over again.So I woke up this morning with my phone on 5G and WiFi in my house was working fineA toggle of WiFi off then on got it connected again, but twas odd and made me think of your issue @bkeaver ... Although my battery didn't take a hit at all.
Hopefully this was a one time thing ...
What did you report?This may be the most productive I've been during a beta LOL Reported two bugs ... Not sure I've ever made a report before.
I've had a few occasions where long pressing the power button or swiping from the corners would not trigger the assistant. Usually a reboot correctedWhat did you report?
Oh okay. I don't have the power button long press for assistant and use it for the power down menu and I use a lot of the long press on the pill but never from the corners so I will have to try and test myself on those twoI've had a few occasions where long pressing the power button or swiping from the corners would not trigger the assistant. Usually a reboot corrected
And I just found out that the media volume and assistant volume aren't truly independent from one another when you're streaming media with a Bluetooth device connected.
https://photos.app.goo.gl/ZPWwL6sUw7EY8YCd7
Yeah the assistant thing is very random and I can't figure out what triggers it.Oh okay. I don't have the power button long press for assistant and use it for the power down menu and I use a lot of the long press on the pill but never from the corners so I will have to try and test myself on those two
