Android 4.0.4 Bleutooth Not Picking Up Plantrontics Pro Plus
RoadMan18
4
This new Android 4.0.4 version does not recognize my Plantronics Pro Plus Bluetooth. It worked fine with the previous version of Android (I'm not sure which version that was). Google should not institute a new version of Android without fully testing it.
Ok ... first of all, this is the Introductions forum, so howya doin'? Feel free to introduce yourself.:cool: Posting your question in the forum specific for your phone might yield more satisfactory results.
Second, it would help if you gave more information--namely, what phone and wireless provider you're using, as well as the exact name of your Bluetooth headset. You said "Plantronics Pro Plus Bluetooth," but I'm assuming you mean Plantronics Voyager Pro+, which is what came up in the Google search.. I also assume you're pretty proficient with how to use the headset, but just in case, check out this link and make sure you're doing everything correctly:
Pairing Guide
Good luck.
mostafamu
