Android 4.2
Does the gapps file change from 4.1 to 4.2?
Um, I'm not sure. Which gapps file did you use? On the CM10.1 thread there is a link, I used the most downloaded file, I forget which it was but the OP said to use any in that thread really. I just flashed 07/28 and its stable.
Sent from my HTC6435LVW using Tapatalk 4 Beta
That is the gapps i used, hmm would it make a difference if i flashed back into my nandroid backup and then flashed cm10.
I'm not entirely sure. I don't understand why it wouldn't work. I'm stumped! I'm gonna update to 07/30 now.
Do u have to update to the 7-30 or can I flash that right from newts rom with wipe and reset? Maybe I will try that instead of 7-28. Do u use rom manager to update?
No, you can flash directly into that build. It's the newest one listed on the downloads page. I'm using it now. And no, I use CMupdater to update. (Its in about phone under settings.)
How long does it usually take to install, it installed in less then a minute when i did it. Seemed a little quick to me. Maybe it just didn't install properly.
The updates are relatively quick in comparison to a new ROM. But I don't remember how long it took, sorry. I didn't notice any difference between CM and any other ROMs.
Aruz530
