Android 8.1 Freezing Problems
  • Start date Start date
A
Android Central Question
My phone is AllCall S 1 X mobile phone, using android 8.1. The problem is that, when the phone is switched off, or the battery drains and you try to switch it on, it cannot switch on. It only freezes on the start screen. Any advice or assistant ?
Welcome to Android Central! Does this happen in Safe Mode as well? On most Android devices, while powered on, press and hold Power until the Power Off menu appears. Press and hold the Power Off selection until the Safe Mode prompt appears. Tap OK.
mersy78
