Android Central Giveaway: 10 FREE Copies of Beautiful Widgets!
Status
Not open for further replies.
Beautiful Add on
I would like to see a nice battery display added. With % left, or battery life left...Put a time on the widget for when the batter "expires".
weather widgets of 2x2, 2x3 widget sizes (more flexibility to customize the size). ability to choose where the weather data is gathered from and click to open in browser optional.
Widgets to disable/enable:
Mobile Data/MMS
Mobile Calls/txts (without disabling Wifi, so it is not the same as Airplane mode which kills all wireless technologies)[not sure if this is possible without rooting]
Bluetooth
Airplane mode
wifi
Data Sync (custom [selectable option] set to sync, gmail and/or contacts and/or calendar, not just all or none)
Syncing of the android MAIL app (customizable to change frequency [i.e.15mins, 2hrs] then the widget enables/disables the email from downloading mail) I would love this for work, enable during office hours and disable after hours without changing the settings via Settings app.
How about the option to bring up the agenda like maybe the next ten or so appointments or events on the home screen by clicking the date. Bigger and colorful power bar icons would be nice for me
response
I would like too see different screen options n update the capability too add different types of widgets to change it up.
You could make a little pet spider that just sits on your desktop and moves around. When you poke it, the spider will run away from your finger! Or with any animal! Kind of like a simplified tomagachi!
Having the ability to put your calendar on the main screen widget in place of the weather would be cool
I would love to see the ability to show 2 different locations temps on the main widget.
re: beautiful widgets
i dont know if anyone has said yet but i would like to see a twitter widget as a new feature for beautiful widgets......:)
Add an option to have a taller widget (4x3 or 4x4), and pull calendar information on the bottom row (basically, combine what calwidget does and add it to the bottom of Beautiful Widgets).
Bit of a long-shot, I know, but I'd love to see some kind of Google Wave integration. I've seen apps manage to pull Wave off in a limited regard, but none of them quite have a beautiful interface.
Add a feature for showing new posts on a vbulletin forum. sort of like an RSS feed, but for forums, specifically vbulletin.
Moon phase peaking out of the weather icon would be nice. I like being connected to the grander astronomical world.
just got this and love it, only thing i would like to see is a break down forcast for weather. maybe ability to scroll on bottom forcast for five day weather and tap to see full forcast for the day.
Status
ellahayes
