Android Highlander Wallpaper
Love the wallpaper, however, getting it fit properly for the Zoom is a nightmare. It invariably tries to cut off the bottom half of Lloyd whenever I try to set it as my wallpaper. Is there a way to make it Xxoom friendly?
More Highlander
I saw that AC tweeted about the Highlander wallpaper but it looks like they said it was Lloyd! :confused: Argh! Anyway, here are a few more, including widescreen versions probably more friendly with the Xoom.
Enjoy!
Reactions: Jrmatics
You should be able to right-click the image (or long press on tablet/phone) and save it.
Ok the splash screen is what I see when I power up right? I know you had simple instructions but could you go a little more in depth because I'm not seeing it on my evo and I would like to have that. I thought I followed instructions but I did something wrong cause I still see the sprint stuff.any help would be great thanks.
Have to be rooted. You download to root of sdcard(make sure it says PC36IMG.zip just as you see. Power down phone, press and hold power and the volume down(same time)
You should see 3 skateboarding android guys. Wait it will find the file and ask if you want to update, press the volume up it will install,and ask if you want to reboot press volume up and it will reboot and you should see the splash screen and then your bootanimation will start after that. Pm me if you have any more problems(dirct.for evo) may try redownloading file make sure you use the link for evo splash
Reactions: puzopia
Fantastic Wallpaper
Keep em coming! They are great....
Wide work great on Droid X.
Reactions: puzopia
Oh man, this wallpaper rocks. I love it. Especially the red one. Not to push my luck, but a red one with the text would be incredible. :P I still like it just the same, though.
Reactions: puzopia
cool now i will have to make a splash from each color that way i can change for mood. good work puzopia
Reactions: puzopia
Another one
Ok I know there's a theme here but, who cares? This was another one I started but never finished. I think I like it better, let me know.
Same thing, with a slight blurr...
Widescreen...
Enjoy!
Miserydhala
