Android N Developer Preview
Re: downgrade from N dev beta to M
I tried it and I'm still waiting for the Ota to come to take me back to marshmallow
If you're still stuck try opting back in then opt out again. That, or try doing a manual update from settings. Like others, within 5 minutes I was prompted to downgrade back to Marshmallow again. Fun fact, in case any of you missed it like I did, opting out does wipe all your data and settings.
I just flashed my N9 and starting on my N5x. Don't think I'll flash my N6p. Need a reliable phone.
I did the same. Flashed my N9. My 6P will stay on Marshmallow as a daily driver.
Posted via my glorious Nexus 6P
I'm really liking this Alpha build so far except for a few annoyances. But when you test a new OS, especially one at this early stage you should know it won't all work right.
- NONE of my Amazon apps will work except for Cleaner PRO. They all force close with unknown error redownload app from App Store. Amazon is aware and looking into this.
-For the first 30 minutes I couldn't dial out. Had a minor panic attack but it seemed to work itself out after I received a call.
-Sometimes after activating hot spot it will turn itself off. I can actually watch the button slide off. Doesn't happen often.
-The longer I keep the phone running the for FC's I get with error messages. So I reboot often.
-I cleared system cache a couple of times and it seemed to help a little...maybe it's just psychological.
Really like the night mode and new permissions set up.
Nice, Google.
Bitterbuthappy
