Android O for the Pixel and Pixel XL.
Found Android Pay, and Fortinet VPN do not work with O. And the lockscreen apps don't work too good. But after clearing cache on a few apps, it works very well.
So far so good on the new beta....no app crashes. Love the battery meter! Glad they are adding that feature.
I am normally good with Beta's and Insider Programs but I have to revert back to N tonight on my Pixel XL. Bluetooth keeps cutting in and out in my cars audio system. Almost unusable...
The only prevent for me is that Android Pay doesn't work... When that is cleared up, I'll make the jump.
Still poor battery even after reset.
Much better bluetooth connection to my Ford Sync. Light years better.
Seems like the mobile data connection is always active. That may be why my battery is dying. When I enabled DO, I noticed that it was selected. I disabled it. We will see.
It works even though when you open the app it says it won't work on preview versions of Android. I just used it @ Firehouse subs.
After factory reset it's now working for me. I have to re setup my bank cards,but it works now. It did retain all my discount cards. Cool beans!
A second system update.
43 mb for me on Verizon. Right now I can only hope it's a proper toggle for the theme. Can't hardly stand the white
Edit. Nope doesn't fix the white theme
Anyone found the Wi-Fi Assistant? I am unable to locate.
Under Network and Internet then VPN. I can't get the key in the notification bar to go away saying Always-on VPN disconnected. I go to the settings and it's on.
URGENT - If you join the Beta but want to unenroll, it says it will do an OTA of the last good build of N but it doesn't work. As it stands, you are stuck on the Beta. Anyone have any tips to force this OTA to go back to N?
kitlis
