Android O for the Pixel and Pixel XL.
Wow! O seems much more a. Upgrade than Nougie was. I am loving it. I have one work VPN client that crashes, and I had to fix Android Pay. Cleared a lot of app caches But, overall O seems much smoother, and I like the new theme. O seems more an upgarde than Nougie did. Really liking it.
Not to crap on this or anyone's opinion but I actually feel the opposite. I thought nougat was a very 'fun' addition to marshmallow and now I feel so far running 'O' a lot of change for the sake of change.
I mean, I'm still going to use it and run the beta all the way through just because that's what I like to do but I feel the ui color changes are ugly and I'm hoping there's finally going to be a toggle for dark theme, and the settings menu is a bit of a mess. Why are things hidden behind this advanced button that was never there and in a few instances just reveal one more option that should just be there to begin with. But who decides what is 'advanced' under, say, my display settings? It is a settings menu for display options like seriously.
Idk just my two cents on a few things but overall, I'm surprised by the stability of this beta build and enjoy being on the bleeding edge and as always this pixel is running super quick and just generally very snappy.
Loaded and running for 2 days now... Been quite stable...only issue is I can't get the picture in picture to work....anybody else has that issue or know how to get it going?
Assuming you have YouTube red subscription try clearing YouTube app cache or uninstall YouTube and reinstall it.
I unenrolled 2 days ago. No OTA to Nougat. Bluetooth will not stream music to my truck. Phone call audio works though and connection to my Bose Bluetooth speaker works. Google Assistant crashes after I ask it to do something. Twitter freezes up after a few seconds also. Most other things are good tho. Verizon pixel xl
Thanks bhatech, I uninstalled all updates to YouTube and it works now and yes I'm on YouTube red.
I noticed a lot of Google apps I can't update from apkmirror. And some like the Google App beta, I can't even uninstall.
If anyone values Bluetooth in their car, do not load the Beta on your Pixel XL, especially the Verizon Pixel XL. There is NO OTA return to Nougat. Bluetooth is totally messed up on my Pixel XL and UConnect.
O fixed all my connection problems I was having with Ford Sync. It was so bad under Nougat the Sync would lock up just connecting my phone. Now I have no issues.
I hate that there is a WiFi disabled icon, even tho I have WiFi turned off!! Ahhhhh Why?!?!?
My truck has Uconnect and Bluetooth works fine except for it doesn't display the artist and song. I'm using a Verizon pixel XL
Has anyone been able to install from apkmirror, or update from Play Store any Google apps like Google, Contacts, Play Store, GMail, etc.?? Nothing from Google will install but Waze, and office apps.
mama baer
