Android or Samsung Pay?
I've gotten cash back tons of times using Samsung Pay. Most terminals ask credit or debit, then hit debit and enter pin for cashback. I enter my atm pin
Your right memory lapse I do that all the time, was thinking of sothing different
Some terminals do ask for a card pin just for security measures. I show them the encrypted code and that's usually the one that they need. A few times it's been the other one.
I've tried both and find Samsung Pay to be far and away the best. Not just the points (12,000 burning a serious hole in my pocket) but ease of use. Android pay locked up my phone pretty bad once I activated it.
K Mart is the only store that didn't work. Probably because they blocking it even when it had the NFC tap location up top of it... I was pissed off. I know many stores are trying to block it Walmart is one of them. Because they want you to use their app instead. It's insane.
In some cases, it's really more about the flaky card readers at a particular store. Works fine at Walmart and Kmart near me, but some people have problems.
Kind of liking the added feature of Samsung Pay giving a notification of a purchase even if you don't use samsung pay.
Is there a way to keep the card from swiping up accidentally? Seems I keep swiping for the SP card to activate when playing around on the phone.
I just turn it on in the lock screen and leave it off for the other places.
Even works on a black screen cool
I finally got mine setup. Now to just use it next time I go shopping.
I used mine this morning to get some drinks at the gas station down the road from my work.
It only takes a glance ones you get used to it.... I don't even have to lift the phone just glance down.
nickmeredith
