Android P Public Beta -- Live!
Status
Not open for further replies.
I have the same issue. Outlook crashes on start. Any pointers on what I can try?
Are you using a Microsoft device management application like intune? If so then that would be the reason your outlook is not working. Mine was working fine until I enrolled for my work email.
Any1 noticed that when activating Bluetooth the icon won't appear in the status bar?
And,
When playing a song on Google play, the cover of the song remaining the lockscreen wallpaper forever 😂
And,
When playing a song on Google play, the cover of the song remaining the lockscreen wallpaper forever ������
Yeah Bluetooth doesn't show the icon unless connected to an active BT device. I believe this is intended.
No but a friend of mine mentioned that too. I think it was solved with a reboot.
Waking the phone up with fingerprint scanner is definitely noticibly slower on P then it was on Oreo. Other methods seem the same, facial recognition and pattern or code lock. When is screen is off and you use the fingerprint to wake up there is definitely a delay though compared to before.
I can connect to Bluetooth in my car for calls and texts, but I have to toggle the Media Audio option on the phones car connection settings from on, to off, then back to on to get it to play audio.
That's what Beta's are for and have submitted it to Google, but at least there's a viable workaround.
Hm I will have to see if I do bluetooth only what would happen. I use AA in the car and so far all functions are okay.
Try changing your Bluetooth AVRCP settings in developer. Setting mine back to 1.6 fixed my audio problem with Ford Sync.
Facebook seems a little buggy with the beta. for example it won't open from using the quick swipe up gesture and selecting it out of the carousel. it also won't open with the quick swipe to the right on the home button if it's one of the last two apps you had open.
Anybody else wake up to an "ambient services keeps stopping" toast this morning?
I had that problem several times last night when I was driving. I'm not sure if it was the 'Now Playing' feature running in the background that was causing it since I did have music playing on the car radio. In any case, it crashed three or four times in the space of a couple of hours and then I haven't seen it since (but I also haven't had music playing in the background either).
Can't delete text threads from the Textra app is the only bug I've noticed so far. Trying to crashes the app. Dev probably needs to update it.
Sending a reply in pulse straight from the notification shade will not dismiss the notification. Not sure if that is a bug or not
It's part of the new reply functionality. Basically you can reply from the notification and continue the conversation in the notification.
Why is that? Be better off if that was an option at least
I rather like it but I could see it being weird when new. You can still swipe the cards away though
Status
williestringfield90
