Android P Public Beta -- Live!
Status
Not open for further replies.
when is the next version of the beta coming out ? does Google usually spread them 1 month apart
There are 2 scheduled for June: one earlier, one later, but no dates specified.
If there's a pool going on, I'll take 6/5 for the first one and 6/21 for the second.
I've always had a shortcut to my settings either on my home screen or on the app drawer, much quicker than pulling down twice.
Yep, I have it in a folder with the calculator and some other shortcuts.
I wouldn't bet against you. I expect the regular monthly update and the DP3 Monday or Tuesday.
Well you don't get regular security updates on beta. So you only get an update once a beta build is released.
Right, I just meant that I can see them coming out about the same time.
Side note, I'm not on the beta anymore. I only ran it for about five days. But I liked enough of it that I am anxiously awaiting DP3 to try and hopefully stick with.
Is there a better way of getting to the settings now? You have to double pull down on the notification panel like you had to do with the brightness slider on Oreo.
I do two moderately quick finger rubs down on the fingerprint scanner. If I were right handed it would be even easier as the location of the settings icon is perfect for the right thumb....
Can anyone tell me if the Android-P issue(s) with Outlook/iTune has/have been corrected?
According to the forum on google+ it is supposed to work with the latest version of intune. I am holding off to update until the next version is released.
After 8.1 they released a final update to bring us to a non-beta state very quickly.
I think it was after the OTA to non beta users though.... Just don't remember how long.
I jumped off 8.1 beta early because connection with Android Auto was flakey.
Status
jariyah
