Android Q Beta Bugs Discussion
Same here on the Pixel 3xl mostly with other launchers though
Yep yep same here. If you look on the Android beta issue tracker, lot of other users are complaining about wonky and janky home screen gesture UI.
Is this happened for any of you guys? When I'm navigating with Maps I go do something else, double tap the PiP window to come back to navigation but it opens up in a weird 2D window instead. This happens every time too but only when using the stock Pixel Launcher. It works normally with all 3rd party launchers
Yep. Been happening here since the last update
Yeah come to think of it, I didn't know what that window where I came from, but from picturing picture mode I do get a weird 2D window where the green navigation bar is minimized and it's hard to get back to the regular satellite view 3D mapping view.
Anyone else getting the Double animation on full gestures since today's update to the Google App. Using Pixel Launcher I get the same double animation effect when swiping up to go home that you get with 3rd Party Launchers. Disabling Google App solves the issue but clearly not an ideal solution.
I uninstalled the update for now which fixed the issue. Was told Google are aware of the problem.
Is anyone else running into this? My app icons are cutoff/blocked by the keyboard.
tvgal
