Android System Battery Drain Absurd!
I'll attach some screenshots, to highlight the issue...
The "unaccounted" category is back, and it's leading with a vengeance... Here is captured a rare case where the screen was off for half an hour.
GSam showing 100% App Usage? Like what does that even mean? Where does screen even get a chance to show up? When it should be on top in individual usage!
More GSam. Look at the first two stats. It's just incredible.
I love this phone, but can't stand this behavior.
GUYS I FOUND THE SOLUTION!
So i sum up all the problems regarding android system battery drain in s7 edge and after applying this settings i got my battery running normal again.solutions are as follows
1. Clear data from google services
2. Force stop chrome , facebook
3. Smart alert off
4. In oreo restrict background usage of android system
5. Check that your cell signal are not low
6. Wifi always turn on select never
7. Google backup off
I applied all those settings and in upcomming time i will check what was the give culprit
Loki Samhain
