AndroidTV box remote power off
AndroidTVuser
Anyone know how to modify the android TV box remote power command? I know some android box has this option in settings.
Right now when I press the power bottom goes to sleep. Long press to bring up the Shutdown and Restart manual.
Are there anyway to change to power off on one press?
One more thing if not too much to ask. How do I set a default app when I power on the box it direct launch the app?
I have a MXQ PRO+ Android 7.1.2 Amlogic S905X came with rooted.
thanks in adv.
Android does shutdown in 2 presses by default, but since it's rooted, try Quick Reboot Pro.
For running an app on boot, look for a startup manager - most of them work well.
Hi Rubat was able to install Quick Reboot Pro 2.1.5 apk. I see in app there reboot/shutdown/fast boot/ safe mode/ etc.. I don't see any option to change the sleep button to shutdown.
Thanks many app works for the app startup.
xinyingt2
