Angry birds score
I'm still working on level 7 as well as a couple others. Definitely a fun game and I'll be picking it up when it comes out.
Still stuck on 7, 11 and 13.
Oddly enough I got 3 stars on 15 using all the birds, but didn't get it twice when I still had one bird left. I guess knocking down more of the structure can give you more points than having extra birds.
But level 7 is driving me NUTS!!!!! (high score of 73,101)
yeah I think destroying the structure as well as killing the pigs(with fewest birds ) gives you the most combined points,
Lev. 7 was my fav ,lol :p
Finally got all 3 stars last night... I didn't have much trouble with 7. The one that took me forever was 2... wtf?! :p
Level 7 wasn't so bad. I've gotten three stars on that several times. Level 15 was (IMO) the most difficult.
***** How to beat level 7: *****
It can be done with only two birds. Shoot at a high angle and come down between the first two towers, aiming for a trajectory that hits the "seam" between the two horizontal boards, going through the diagonal board and hitting the second pig from the left. Make sure that you accelerate on the way down. If done correctly you will kill the one pig that you hit and cause the towers on either side of your impact to topple outwards. The first tower crushes the first pig, the second tower collapses killing the small pig and destabilizing the rest of the structure. As that collapses the third tower will crush the last pig. Once this is done you'll be left with only one pig remaining, which should be an easy direct shot. With the 30k in leftover birds and 25k for killing the 5 pigs, all you need to do is 20k points worth of damage to get the three stars. That's easy to do.
I suspect that if you are very lucky you may be able to take it all down with a single bird, but I haven't been able to do it yet.
I don't remember having much trouble with 7 either. Could have been one of those times where things randomly fall because it didn't seem that challenging to get three stars the first time around.
I think I tried level 1 the most times before getting 3 stars. The same thing kept happening, then finally it worked but I didn't know what changed.
Well, all ye gurus, can somebody give me a hint on level 15?? I have my 3 stars on every other level, but I think I've tried level 15 at least 75 times with no more than 2 stars! I had to walk away for a few days, it was effecting my quality of life. :p
just keep playing until you get them? that's how I've been doing it....though I could help you out a bit and post my high scores -I'm only 3 levels away from all three stars
1 - 32790 = 3 stars
2 - 35630 = 3 stars
3 - 52690 = 3 stars
4 - 47310 = 3 stars
5 - 56330 = 3 stars
6 - 38390 = 3 stars
7 -
8 - 57760 = 3 stars
9 - 90320 = 3 stars
10 - 60370 = 3 stars
11 - 77430 = 3 stars
12 - 65150 = 3 stars
13 - 73810 = 3 stars
14 - 103040 = 3 stars
15 - 80860 = 3 stars
EDIT: finished 12 and 13 finally - now to just figure out 7
Hello, I just wanted to add my high scores for the fun of it (All 15 are 3 stars)
UPDATES=BOLD
1 - 34950
2 - 36520
3 - 54790
4 - 49270
5 - 63070
6 - 40380
7 - 75100
8 - 62660
9 - 104180
10 - 61110
11 - 81260
12 - 68210
13 - 76970
14 - 118870
15 - 84190
Joel
I'm still stuck on level 7. And I think I got lucky on 11 and 13 but have no plans on trying them again.
But 7, geez, I have tried everything I can think of. At the moment I don't want to read the help from the post above I want to try and finish on my own, I just don't know how long I can hold out.
I don't even want to imagine what will happen when they release 150 levels!
Finally scored 3 stars on level 7 to complete all 15 levels. I need a full release.
That's what she said.
I got through level 13 before knowing about the "power-ups" - tapping the screen to split the blue birds or speed up the yellow birds. doh! Almost made it too easy, though.
Dave
ditto. 3 stars all levels.
Now what?
lol :p wait for the full release "der" lol , I wished they had the white birds that dropped the egg bombs(like on ipod) in this beta version.
The red bird is kinda lame lol
Now... give me a hint on level 15! :p I tried it 15 more times last night (for symmetry's sake) and still can't get better than 77200...
sorry no hints from me, 15 times isn't enough. I have spent over 2 hours on some of these (not at one time)
I am stuck on one star on level 12. is it better to split the birds at the highest part of the arch?
The way I did it was to aim so they land near the middle...and split them right before hitting...to concentrate the damage into a smaller area...and hopefully get the TNT to blow...
*************** To get three stars on level 15 ****************
With your first shot go through the "front wall" by aiming at the "hollowed out cubes." You want the bomb to shatter a cube and go all the way through and land on the wood on the other side before exploding. That should take out the two pigs closest to the front along with all of the "front wall" and most of the "front underground" portion. Shoot your second bomb over the wall, past the two points in the middle and land it on the wood at the base of the back tower. Then it blows it should knock the tower down onto the pig int he back AND (if you're lucky) the force of the explosion will detonate the TNT at the bottom. In my experience you need to clear this level in two shots and take out most of the destroyable bits in the process, which is made difficult by much of it being made out of stone.
Reactions: Revolutionary
sunita94
