Another update for AOD
Where's the Verizon 3D touch update?
??? No such thing on Note 7. The note 7 does not have the hardware to support 3d touch. There is an option that Verizon has not implemented yet that allows for a long press to bring up a menu of options.
Of course it's not true 3D touch but it's close enough...found on the tmobile version of note 7
Interesting, thanks. How do you access that menu exactly? Long press does other things on Android, so what is the interaction there?
Also, unless other apps have more useful options, those 4 on Twitter don't do mcuh for me (maybe "put to sleep", not sure).
It's just a long press menu, every icon have the same 4 options or part of these 4.
Pls dun compare this to iPhone's 3D touch, it totally is not that. We are totally going to get laughed by Apple fans if we call it "Note 7's 3D touch".
Thanks. Looks interesting.
Also, I don't really care what it's called, nor would I care if anyone laughs to be honest. :-)
I don't care if Apple fans laugh either. If anything else that just means that they'll spit out their pumpkin spice mocha-frappucino's all over their iPhone.
I never saw the point in "3D Touch" anyway. I only messed around with it to see but I went back to using the apps the normal way. Usually was a lot faster.
Actually some apps have another option instead of uninstall...the Facebook and hangouts apps gets the disable option ....
gianfranco
