Any Charging advice for S8?
John_Wakatoshi
how do you charge your S8?
i've been thinking if its okay to charge it even if its still on 20% battery and its bugging me if its good or bad thing to do....
and sometimes i charge it even if there's still 60% and unplug it on 80-70%. is that okay? thanks in advance!
Hey John 😃 Thanks for the question. The best advice that I would give you is never let the battery go below 15% to ensure you keep it in a healthy condition.
I say this because there have been some members saying that they ran their battery down to 0% and then had trouble charging and booting up the device. So just to be on the safe side, I stick to a minimum of 15%
Other than that, you can charge it as little or as much as you want on any percentage. So even if it's on 80% you can still do a quick charge to take it up to 95% if you want. It certainly won't affect your battery in anyway. Hope this helps.
Charge as you want. I go mine if several times a day. I have a wireless charger on my desk and I just leave it on there when I'm in the office. I rarely go below 80%.
I typically charge mine when gets down to about 5% and I've done this for every phone I have ever had with no problems. Like mentioned above, charge whenever you want though. There's times I put mine on the charger at 60% or even higher.
DannaOgle83
