Any Galaxy Gear owner worried about scratching the screen?
I've been using the ArmorSuit Military Shield from Amazon for my Gear. Some dust collected on the edges but that was a minor annoyance compared to dealing with a scratched up watch.
Within 2 weeks my galaxy gear had more scratches then you could imagine!
Unless you live like a princess, you will scratch yours. You will also regret that scratch everytime you glance at your wrist.
Get a protector for it, or only where it occasionally.
Mine scratched-here's what I did-buy a cheap protector-use as a template on whatever make u like on ur phone and there u go-I like the tech 21 screen protector and by the way, crystalusion does not protect from scratches-also saw privacy protectors for gear on Amazon
Most initial reviews I read specifically mention the resilient sapphire glass display.
The gear s3 is corning Gorilla Glass SR+ which is specifically made for Samsung and is comparable to sapphire crystal in hardness. I am running without protector because the frontier (s3) is recessed, and this should also prevent damage.
The S2 classic I have has a protective glass and it is not visible @ all the reason I fitted it was because the glass is not recessed and was worried about catching it. The previous watch to that was the neo and I had to replace the screen because I scratched it badly with sand whilst folding a hot air balloon up. The hope this helps.
heritagevine07
