any leak peeps get ice update?
Well I got it working, the first file I downloaded was 40 mb short but the new one is working great thanks for all the help for everyone. If anyone else is have problems check the file size.
Good deal
Sent from my ADR6425LVW using Android Central Forums
You get it working?
stock ReZ. I'm ready to unlock and root
No,I deleted the .10 file,named the .12 file ph98img.zip,put it on the root of the sd card,get into hboot,go to recovery and all I get is a green arrow circle followed by a red triangle.any advice,I'll take it
When I flashed .10 all I did was put it on root of ext sd, turned the phone on hboot and it started doing the flash on its own.
Sent from my ADR6425LVW using Tapatalk 2
i would make sure if you named it on a windows computer you didn't name it ph98img.zip.zip as by defualt windows hides known extentsion
Reactions: mike7728
That's what happened,so with mine I just have to name it ph98img?
Thanks to all for your help with flashing the .12 leak.:D
@Mike
You should install "astro browser" from play store. Search all files on SD card and delete all the ph98img.zip files you come across. The download this file http://www.mediafire.com/?b8uohf4gf9epdsy I know for sure that this download works. Its a fairly fast download too! Then use astro again and find the file(it should be in the download folder under SD exd) long press it, rename it. Long press again and copy it. You need to put it under SD 2. Make sure fastboot is off. Go to hboot and it should start automatically. Flash twice and enjoy. That is exactly how I installed .12 earlier. Hope this helps
Reactions: jonvoight's car
I downloaded astro and found 98 zip file but i can't find a way to delete it.
That worked. I went right in to the sd card instead of the way u sent me.
05x199x
