Any LED light notification apps working in 4.4.2 for anyone?
here's what mine looks like:
I showed a picture within light flow. Choose notifications. Pick an app. Set it up. Poke the icon on upper right. Shut off screen. See if led lights
Beamed from my Galaxy Note 3
Found a new app called Light Manager. I like it better than Light Flow and it works flawlessly with 4.4.2.
Sent from my Nexus 5 using Tapatalk
What makes it better than Light Flow? I've never had any issues with it?
Well for one thing, it doesn't kill my battery. Light Flow does - I'm not sure why, and I know this isn't the experience for everyone or even most people, but it is mine. For another, its free version lets you add any custom app you want to the panel of customized notification lights - you need the paid version of Light Flow to add certain apps. For me at least, Lightflow's free version always took a little while before the settings would take hold, for Light Manager, they work immediately.
I tried light manager. Set sms color to yellow. It comes out green. Can you get a yellow notification led?
So I gave Light Manager a go, uninstalled Light Flow so it wouldn't interfere and set up Light Manager -- it didn't work at all for me. I tested sending myself some emails, they arrived and the light flashed very briefly once, and then nothing. Tried again and again, gave up and went back to Light flow which worked right away. I agree Light Manager being free and letting you use it with all apps is a nice feature, but in my limited test run it didn't work.
Sometimes these apps need a restart. Did you try that?
Anyway, if lightflow works better for you, stick with it.
Lightflow uses about 4% of app usage (maybe 2% overall) which is a little high but I wouldn't call it a battery sucker.
In note 3 cannot produce yellow. If you choose yellow you get green
I wouldn't either. But that's not what was happening to me. It was eating up as much battery (sometimes more) as the screen. And that also started after the 4.4.2 update to my Nexus 5 - it was fine before that.
I should also mention that even independent of that, I'm liking Light Manager better.
I'm a Light Manager user. Works great on my Nexus 4 and Nexus 5. I think it's better than Light Flow.
Sent from my Nexus 4
I must admit I am not impartial because Andrew of Light Flow is the most responsive developer I've ever dealt with.
I know there's a few minor bugs that still need to be worked out with Lightflow on Kit Kat, but Its working great for me. I've learned that when I reboot my device I need to open Lightflow to activate it again. I think this is a known bug, but it works fine after reopening the app. And I don't reboot that often.
I don't notice any battery drain with lightflow. At the end of the day it might show at 2? battery use, but with all the notifications I receive during the day that is more than acceptable.
And like someone said earlier, the dev is very responsive and working on improving the performance on Kit Kat. I've been very happy with lightflow but it's nice knowing there's other options out there.
Any of the above mentioned 3 apps support alternative lights indication?
I tested in "LED Blinker Lite" with blue and red, but it did not work. After receiving two different notifications, only the blue, light from the 1st notification, blinks continuously.
Thank you for your info, regards !
SLo
Last night beweather killed my battery and I have it set to sleep at night. There is just no telling what and why some app decides to eat your battery
Light flow is giving me problems when i get a call, it keeps blinking the LED light after the call is gone and i can only get rid of it by turning off my phone. How do you fix this?
pamatika
