Any LED light notification apps working in 4.4.2 for anyone?
I am also facing the same problem... My LED keeps blinking even after the call ended on both Light Manager app & Light flow. Any help on resolving the issue???:(:(:(
Download LED blinker pro, the best out there right now and works absolutely perfectly on the nexus 5
Light flow is giving me problems when i get a call, it keeps blinking the LED light after the call is gone and i can only get rid of it by turning off my phone. How do you fix this?
Go into light flow, click tools. Then click on all led test. Lock phone. Unlock phone, go back into the app click on stop test, and your problem should be gone.
Posted via NSA Spy Van 37...... Free candy??
Just picked up android v.4.4.2. Lightflow lite is working on LG G2 after uninstall and reinstall. However, can't find where to set it up for multiple notifications so that it cycles through all chosen colors. It just flashes whatever the first one is and then the next only after you clear initial notification. Any answers???
kmerphone6
