- Feb 6, 2017
- 99,109
- 15,816
- 113
Ok fixed , had put my att sim back in that I originally signed up for beta , all good now .I still can't log into beta community to report errors and I'm on beta lol
Hahaha, alwaysthis can't be loaded with Odin can it?
Nvm just found out it can![]()
Hahaha, always)
Nah...your always welcomed here , people get busy and understood.Lo I feel bad for only popping up around here when there are software releases![]()
The beta is closed for unlocked devicesI started checking yesterday morning and the banner never appeared. App is current and I cleared the cache and data. Unlocked/Verizon. Is there anything else that I can try?
You can flash the beta through odinI started checking yesterday morning and the banner never appeared. App is current and I cleared the cache and data. Unlocked/Verizon. Is there anything else that I can try?
Yeah unfortunatelyWill updates have to be installed through odin, as well? Also, I've never used odin.
Yeah unfortunately![]()
Just flash to public released android 11 and then back on the update schedule.So, then, what happens when it's out of beta? Will I be able to upgrade as normal?
I'm on it. locked Verizon version. was a pita.. but finally got it done
Flashed with OdinHow did you do it? I'm on Sprint locked.
