Any S8 users having problems with Gboard voice typing working?
I concur about the signal strength if it's weak it doesn't work very well what I really find frustrating is if I talk to text longer than the display timeout I have set which is 30 seconds it's not smart enough to stay on and the screen will go off you think it would know better to stay on
Thanks, but it doesn't even initiate the voice typing half the time that occasionally does work though. Do you have any clue how to figure out if a specific app is messing it up?
Same issue. Mainly notice it when using Textra. I'll press the microphone and it will flash, but never listen. A restart of the phone or enough times of opening and closing the app will get it to working again. I switched to Swiftkey when it did it last, and Swiftkey voice typing worked flawlessly. And both use Google voice dictation
There was an update to Gboard vand mine seems to be working fine what about you?
SKGcoshatt
