Anybody Have 4.4 OTA?
Got mine in yesterday... Not much of a change, to be honest, at least at a glance. I still need to check battery life, feels a bit better, but it's hard to tell so early.
Sent from my Samsung Galaxy Note 3 via Tapatalk
Still waiting...I've even tried the framework trick and still haven't got the update..I'm about to give up and just use 4.3 jellybean
Why did Google disable transparent navigation and notification bar system wide only on Nexus 10?! I heard if you install Nova Launcher beta on N7 (2nd) and Nexus 4.. So I tried latest beta version of Nova and it said my device is not supported with transparent bars..
Sent from my Nexus 10 using AC Forums mobile app
The hardware acceleration for various transparency varies from device to device, depending on the GPU. Supposedly, the N10 doesn't have whatever required accelerated support for that particular effect so if it is turned on, performance and/or battery life would suffer. Seems hard to believe considering how powerful and recent the N10's CPU/GPU is, but that is the official explanation.
Yeah, I really would love an explanation for this, both why isn't it available with 4.4 or why cant Nova make it possible with thier launcher. It doesnt make sense to me. Are you saying that if I install Nova beta on my wife's n7 I can get it?
I downloaded the new transparent launcher (GEL) on my way Nexus 10 and it works just fine, Unknown why Google did not included it.
Can you give me the link of new transparent launcher??
I just tried GEL launcher from Android Police and there's no transparent bar. How did you enable the transparent bar?
Sent from my SGH-T989 using AC Forums mobile app
Just got mine on my Nexus 10. Still waiting on my 2013 Nexus 7.
Sent from Samsung Galaxy S 3
well i just got mine. my enthusiasm was tempered somewhat by the constant boot loop situation. rebooted recovery and wiped data, but the boot loop continues. :(
Can anyone who's gotten the update verify that Flash no longer works? The Nexus 7 users say it's no longer working with 4.4. I don't know why it would be different with the Nexus 10, but who knows. This would make me seriously consider not taking the upgrade.
Sent from my Nexus 10 using Tapatalk 4
Hey, I can confirm flash no longer works :-(...
I Received the update on my Nexus 4. (The awesome new features in kit kat makes up for broken flash though.)
I still have not received it on my N10. Should I get it before thanksgiving?
Got the OTA for both my N7 and N10 today and no problems found on either. Live in WV.
albrens
