Anyone else still having problem with WiFi?
This fixed my Wi-Fi problems.
Tuning wifi settings
in settings -> wifi -> menu -> Advanced
Check Best wifi performance
Select wi-fi frequency band and check either 5G or 2.5GHz bands.
Changing IP options from DHCP to static
in settings -> wifi
select your wifi network and keep pushing. it should bring up the menu ( forget network/ modify network)
select modify network
Check "Show advanced options"
change "IP settings" from DHCP to Static
Choose your IP address and other options such that there is no collision with other devices in your wifi network
Just for the reference, these are my values:
IP address: 192.168.1.125
Gateway: 192.168.1.1
Network prefix length: 24
DNS 1: 75.75.75.75
DNS 2: 75.75.76.76
Sent from my HTC6435LVW using Tapatalk 2
That works great maybe at home, since i'm often connecting to multi wifi (even 2 wifi at home) static isn't a option..
Yeah, unfortunately it will only work if you can maintain a static IP. this won't work for me at school unfortunately.
Sent from my SCH-I905 using Tapatalk 2
My internet speed today.
Sent from my HTC6435LVW using Android Central Forums
Thread Rez to say that Verizon is sending me a replacement DNA for the Wi-Fi issue and the SIM card issue. I'll update if the problem persists.
BekaH
