Anyone flash 4.0.4 yet?
You can ALWAYS return to outta the box stock. Don't worry about that. They state that for the fact that they don't know who is doing what and how.
Yes, I upgraded stock 4.0.2 to the leaked stock 4.0.4 OTA using the XDA toolkit 5.3.
Quick and painless. Have not {yet} found a reason to root, but it is unlocked.
With the new adb backup capability, I was able to keep all my apps. Only the icons/widgets on the homescreens needed to be reset.
Battery life much improved (no more Android "Keep Awake" issues)
If you prefer a more GUI method, try Wug's toolkit.
I did this last night with the AC guys during the Hangout after the podcast it was very easy and painless
Thanks to all for the great discussion! I'm almost ready to go, but...
A newbie question that I can't find the answer to - If I flash to 4.0.4 now, what happens when (if?) Vzn finally pushes the OTA version? Does it reflash, or see that it's at that level and do nothing? Thanks!
I'm rooted using codename rom. Will I still get the ota 4.04? All I keep hearing is to revert back to 4.02 in order to flash the update. I flashed the updated radios no problem. Basically will I get ota updates with custom rooms on my gnex?
ecomranx26
