Anyone get the IR blaster to work?
I have Panny Plasma in two different rooms and Sammy LCD in Bedroom plus Comcast Anyroom DVR setup and Sony Blu-Ray, all works great provided you are within about 10 feet range. It isn't as effective if you are at an angle however. I just wish I could control my Sony receiver and XBOX360 with it. NICE FEATURE OVERALL!
How about adding some kind of amplifier externally to the phone. I'm thinking some kind of small zoom lens or crystal embedded into a phone's external protective cover opening. I have a soft rubber case that has an opening that I could stick some kind of device in to make the IR's blaster larger or more powerful somehow. Just don't know what to use. Anybody got any ideas here?
The LG G2 and LG G2 mini it can works with third party Universal Remote Control applications from Google Play Store if you update to Android 5.0 or higher. I recommend to use the Universal Remote Control Free with many devices TV , A/C , Cable box , Blu Ray , Home cinemas and others.
davidlmcshane
