Anyone have the 4G fix?
My /data directory is empty. No "misc" folder, should I just flash wimax?
it's not data on your sdcard. is that where you were looking?
data>misc>wimax>XXXXXXXXX.tree.xml
add:
oh, yeah. like d3xn2o. use Root Explorer.
It's fixed, thanks for the help guys. Yes I found the file after using root explorer. Astrology does not show the file.
So everyone Knows...
My fix was... Deleted the XML - Reflash Wimax Radio Update Profile / PRL
Turn 4G on and Bam! connected...
Tried that and it didn't work for me. Keeps getting stuck on the "obtaining IP address from Sprint"
Any other suggestions anyone?
At firs it didnt work for me. I had to make sure that the 4G was turned off before I deleted the file. Once I turned off 4g, delete the file, turned it on, it worked.
Ishimwe
