Anyone having problems with dialling numbers missing?
kjell_leo
7
Hello everyone,
I have noticed a strange bug on my Nexus 5 and I wonder if I am the only one or someone else is having the same problem.
1. When I am going to make a new call I open up the "dialing app" (Blue phone logo).
2. I want to insert the number myself so I press the "number icon" in the middle below.
3. Here is my problem, the dialing numbers dont show! Only the "call symbol" below.
4. But if i go back and then press the "number icon" again the dialing numbers show.
Is someone having the same problems as me? Is anyone have a fix for this problem?
Thanks!
Re: Dialing numbers missing [LG Nexus 5]
Yes. Mine does the exact same thing and always has. Not sure what causes it but it is annoying.
Do you have any Developer Options turned on? I seem to remember that one of those options might cause a glitch that requires a double tap of the keypad button to bring up the keypad, but I might be imagining it.
happening to me too,this is maddening,coming from a note 2 where the dialer was very nice
just did a google search and you are correct,just turned off animator duration scale and all is good now
cinemacritic
