Anyone know how I make my cell phone open my apartment building door?
jgawrych
I need to press and hold "9" for 3 seconds to buzz someone in. I have a Samsung Galaxy S3. When I press and hold the "9" key, the tone does not last long enough. I tried pressing multiple times with no success.
Is there any way to make a cell phone do this?
Thanks
You need nfc enabled door locks but I think the range is quiet short.have a look on the net
Posted via Android Central App on my s3 GT 19300
Thanks
You may be able to find a dialer app that allows changing the key tone. That is the only thing I can think of.
pramanj96
