Anyone know where to find the water live wallpaper with autumn leaves
Re: Anyone know where to find the water live wallpaper with autum
Hi, I'm in the same situation. Bought the Samsung glaxy S2 T989 (t-mobile) and its missing the that beautiful water with falling leaves screensaver. I had it on my LG Optimus G2x and also on my LG optimus P509, both were t-mobile phones. Has anyone truly found the same screensaver and been able to install it on a new phone? If so, I'd love to hear where they found it. I still have the LG G2x phone, is there a way to id the installed screen saver files and just copy and transfer to the new phone? I don't see anything that looks like a screen saver file when I use Astro. Thank you
I got some water themed live wallpaper at Android market which I liked.. You can check as well...may be you get what you are searching :
1. Mystic Apple in Water Locker:
J1I0VoeMf0-7xAGagnCu2ivVklk637IG_BrAdgXewOTrSKVJMc5XxnMPseyD_HVSpsWA
Check this out at:
https://forums.androidcentral.com/e...terapple&feature=search_result&token=HbT3SAOA
2. Dolphins in Sunset HD GoLocker:
lN7Gy5Ud-5p2YhaC2chvqWBpZMCWPo_n0wKQlsRqEkhA7HWpABbOgYlhhPs1CaoYIQ
Check this out at: https://forums.androidcentral.com/e...dolphins&feature=search_result&token=r18CIWVO
3. Fish Aquarium Go Locker:
JaJyURUvZJTKjhW0ZoxJIg1ZeW_fRtAPoyXCbaH92WW2lofQdQFc443DdewZDoCiiZI
Check this at:
https://forums.androidcentral.com/e...golocker&feature=search_result&token=O7RvzLRC
4. Sea Side Surfing
dYe7v8B_IrsQRJ0XeQOVixtJiIPnyiI8UJCJ38XSSrYWI1C-A1kIFLbRaSmhdsKzrbZD
Check this out at:
TJnY24FfNqNHAEzkDtV5KZWcqqcUkrOvs_KX9YoE7EkEqtUjzpBtjTqvS9N15Dhu5w
5.Opera Sydney Go Locker:
PiHXHV5Xqctd6haJPutDtnEStgKBwZCAMHM_l-y9CJIK-2XhaadSUZC3YuvLN6PnA2wV
Check this out at:
https://forums.androidcentral.com/e...golocker&feature=search_result&token=DFjA-sVb
6.Falling Leaves Live Wallpaper:
TTHxyDjzCyxZOGd5xLcdvvtljb-PCmq6NWk7e8WGKXdnRRiVl5NBwdmGrUEhWIcMpg
Check this out at: https://forums.androidcentral.com/e...allpaper&feature=search_result&token=eRqqETxs
7.Dolphins in Sunset HD GoLocker:
sG5OVCeQ3m3vaI5glfJgI8dxhFlOpF1sJq6SSsqFQsBFyD5g0mgLN_SHJi0X4j2xug
Check this out at:
Enjoy Android apps!!
I have downloaded the attached files they give but when I install it, it says application not installed, my phone is Samsung Galaxy Young (GT-S5360).
You may not followed the proper method of installation better try it once again.
the water with floating autumn leaves comes with xtxperience-7 zip file. (sony xperia s )
r3dpuk3
