Anyone not have ANY problems with the update?
Who updated and has or does not have issues?
  • Total voters
Aggreed!!!
why do you not create a poll, "no issues" or "have issues". This way you do not need to read the post and listen to people complaining. You might also get a count of dinc users on this site. (do not have "not installed" because you only can post once)
To go a step further on the poll, you can give 4 options
1. No issues (upgrade from stock)
2. No issues (upgrade from root)
3. Have issues (upgrade from stock)
4. Have issues (upgrade from root)
It will give a good read on who has issues and if some issues might be related to upgraded from root or not.
Just a thought.
No problem, updated like clockwork. Best of all, it fixed the problem I was having
where my bluetooth credit card scanner wouldn't connect.
Issues? Do you mean install failures, OS bugs, or our own problems with the features lists?
I've noticed one little quirk where upon rebooting my DInc I can't swipe down to unlock it unless I press the the power button to turn the screen off then on and I can't get it not to do that.
Im not rooted and I used the OTA file posted this morning. Thanks
I am having the same problem, a minute or two after reboot, the screen freezes, and the only way to unfreeze/unlock it is to press the power button off, then back on, and move the phone around a bit, then it unlocks it. I think it has something to do with the g-sensor, cause I can't get it to unlock unless the phone is moved around.
Keeps opening randoms apps. I keep killing them but it keeps restarting them
This is not a problem, just the way it works. You shouldn't be seeing any negative side effects from it. Dump the task killer and stop obsessing over it. It's not a blackberry.
updated this morning following the steps from the main page...now i can't hear out of the ear piece. i can only hear people in speaker mode and i cant figure out how to go back to factory 2.1. Did factory reset and several battery pulls :o
did you figure out a fix for this? one of my buddies on a Dinc is having this also..
I just got the update this morning, and so far, so good. I'm loving some of the new features. The Incredible just got more incredible.
Had a couple of issues with my music files but can fix that, the only issue I see is I was assuming that the update would fix the Friendstream app, but no. Anyone else having problems with Friendstream?
I got the OTA update notification, clicked on the "More Info" button and after reading about the update clicked on the "Install" button.
Everything seemed to be going well and then I got the triangle w/ an exclamation point on the screen. It was there for a while until I pressed the power button.
This took me to a menu with options to reboot and a couple other things. The update.zip file never d/l'd and now that the Incredible is back in 2.1, I'm not getting the update notification again.
Should I just use the available ROM to update or wait to see how long it takes Verizon to push the OTA notice again?
Also, under Menu - Settings - About Phone - System Updates it shows that my Incredible is currently up to date. Software Version shows 2.1-update 1.
Suggestions?
Thanks!
Mike/KD6FTR
I got the update this morning. No issues. Battery a little low but I think thats only because I haven't fully charged my phone after the update this morning.
xinyingt2
