Anyone using Nexus 4 on Straight Talk?
Just ordered my st att sim. I don't know wtf I am doing as Ive been on vz. I just ordered the sim for now and I'll get the service package once the phone gets here.
Hope it all goes well with the apn settings an stuff. Going with a new number and just get it forwarded from my vz number for now.
This first month I will pay vz and st ~ $110 yuk.
I really like how you can just switch to tmo with just a sim change.
Re: Anyone using Nexus4 on Straight Talk?
Straight Talk AT&T Compatible Micro SIM Card the same as the T-Mobile one? Does it matter if it says it's an AT&T or T-Mobile Compatible Micro SIM Card? I want to use the Straight Talk T-Mobile network on my Nexus 4. Can anyone give me some pointers? Thanks.
I am trying this N4 out on Straight Talk, using the AT&T compatible sim. So far I am liking it. I still have my Verizon account, five phones. But if this "test" goes well, I will move my number from my Verizon account, leaving the rest of the family on vzw for now.
I have been with Verizon since long before they were Verizon. Nearly 20 years... I have been enjoying 4G LTE for a year. I was worried the nexus would be to slow, but I can live with these speeds.
Speed Test runs at same time...
HTC Rezound on 4g LTE...
Nexus 4 on Straight Talk (att)...
If you want to use T-Mobile, get the T-Mobile sim for the Nexus 4.
I'm with ST T-mobile. In Washington DC, I got 14.88Mbps down and 3.18Mbps up. At home in Potomac, MD, I only get 1.06Mbps down and 1.25Mbps up.
I called Straight Talk and the representative said they don't have T-Mobile Micro SIM Cards. They only have AT&T Micro SIM Cards and standard size T-Mobile SIM Cards. So would that mean I need to buy a standard size T-Mobile SIM from their website and manually cut it to fit my N4 in order to use the Straight Talk T-Mobile network?
Yes. If you want to use ST on T-Mobile's network with the N4, you have to cut down the standard SIM to micro size.
Yap, for now that's your only option, I bought a sim cutter off eBay for 6.99 and shove your existing sim in the direction shown on the cutter and punch away. No need emory cloth, clean cut as a whistle.
I took mine to the local T-mobile store and they cut it for free.
Thanks for the info! :)
Question I'm using net10 with att Sim card and get hsps + 15. I'm in NYC is there any better APN setting to get faster speeds? Also can I call net10 to have them switch to the T-Mobile Sim to test their speeds ?
Net10 only has 3G data, correct? No HSPA+?
I am using Net10 and I get HSPA+ 15 in the Louisville area. I am getting up to 5+ MBS down and a little over 1 up with ping times around 100. Not the fastest times in the world but I have WiFi at home and the office so it is fine for general searches and productivity for me. Over all I am very happy with Net10 so far.
i thought net10 uses att's or t-mobile's network so shouldn't it get hspa+21 (att) and hspa+42 (tmobile) in compatible areas? and would this be the same or different for straight talk?
So ive got 2 plans I have been trying. the $30 tmobile deal and $45 ST with ATT.
Tmobile is fast and seemed to have pretty good coverage. When out and about no issues. Really satisfied for $30 a month. BUT then after a couple days of great experiences i had to go back to main job site. Its not the best for cell service since its enclosed and built to withstand F4 tornado. I cant get any data service at all. We have VZW and ATT repeaters but no Tmobile. So this totally blows as i cant see any way to get this to work for me.
So I decided to try the ST using ATT. $45 isnt near as good a deal but its really the only other choice i think. Got everthing set up and starting testing at home. Data speeds are horrendous. I mean like crappy 3G speeds, TMO was 12-15 mbps at home and with ST I am getting 2-4 if i am lucky. I do get full signal at work and speeds around 7-8 mbps. I testing a couple other areas and was getting 5-7 mbps. So for me ST means much slower rates but i do get a signal at all key areas for me.
So its really hard to say for me. I am used to LTE and great speeds and coverage and both of these routes are lacking in some area. My VZW bill is around $74 a month with the unlimited data still also. So while saving $30-40 a month would be great I am not sure if i can commit to either of these options yet.
verizon @ just $74 for unlimited data? i know you are grandfathered in from the old plans, but i didn't realize it was this cheap. will you get to keep unlimited data for as long as you stay with vzw?
Yes they do both AT&T and T-Mobile but you select the one you want when you order the SIM. I selected the Unlocked GSM option and I appear to be on the AT&T network. You can order a T-Mobile but not in the micro SIM size.
He probably gets some sort of discount. I'm paying $82/mo on VZW for unlimited data/text/450 minutes because of my 10% discount from work.
oh ok. yea right now on sprint i'm actually paying $67/month because of a 25% work discount. but my download speeds are only like 1.5 mbps lol (no sprint LTE in my area).
yea i know i already have a micro att sim from straight talk, i was just asking about the data speeds, like shouldn't straight talk att get hspa+21 and straight talk tmobile get hspa+42 for compatible areas? or are these speeds just for the actual postpaid att and tmobile?
yes i get a discount from work and I am on the same 450 minute plan with unlimited data. I am due for an upgrade right now and if i use it then i am pretty sure i lose my unlimited data. So i can buy phones outright and keep the unlimited data but im not sure if unlimited data is worth that much. I normally am under 2gb a month anyway.
If i do stick with ST or tmo then i would port my number to google voice and swap the number on VZW so I can keep my unlimited plan. I can also then stop service for 3 months with no payments but will have to start back up again after that. Lots of options and no real sense of what i am doing yet.
Oh sorry i guess I miss understood your question. I would assume that the main carriers would reserve some bandwidth and speed for there own customers instead of giving all the benefits of their network to the discount MVNO's. Just my thoughts though.
Jackwills2567
