ApeX 1.3.0
I wouldnt update with Nex theme 1.2.1, The Apex 1.3 comes with the Latest Gapps (Gmail, Voice Search, Search Bar)
one can argue that you could manually update these later but going 1.3 Rom to to a 1.2 theme is like 2 steps forward, 3 steps back IMO.
agreed, 1.3 is so sick it doesn't need more than the gingerbread theme. it feels like we already have a stock version of gingerbread on our phone! consider it an early christmas gift!
I just dl and installed in rom manager. Not going to theme this yet. Looks nice and slick. Ok well maybe I will in a few days. :)
Sent from my DROIDX using Tapatalk
Anyone having issues with browser. Mine is so slow on wifi and 3g.... wait never mind. A wipe of all things browser fixed it.
So, before I attempt to put ApeX on my DX, basically I've downloaded the bootloader and made a recovery backup, installed Titanium and backed everything up there as well, then backed it all up again from my SD card onto my computer.
Then I download the .zip file, wipe the device, bring up the bootloader and install the .zip file, and she's done?
First rom I've put on my phone and I love it!
Well after seeing this I decided to take the plunge. Must say everything has been flawless! Z4root, decided to do a wipe, loaded up the rom and am overclocked and back to normal. Thanks! Two months stock was good for me. Saw it on Droid-Life about two hours ago. Took about an hour.
Ok, I took the plunge as well. I love this rom! Took a little figuring out as this was my first time a few stress filled minutes later all is well!
Sounds right. Get on new leak or ota. Then flash this new apex.
I updated via the .340 zip file that was hosted a few nights ago, not OTA. Should I move this file somewhere safe on my SD card to back it up?
It should be safe right where it is! Or you could delete it as it isn't necessary anymore. I did same upgrade path as you and didn't touch the update.zip. I think once the phone is updated that update.zip is pretty much trash. The .340 sbf might be something to have
Where might I find this?
My Unstable Apps DX/D2 Overclocker wont work after installing this. My settings are 1.2 at .63, same as before, but after my 90 second delay, the phone just reboots. I uninstalled it (phone ran fine with it gone) last night and reinstalled this morning. It went right back to rebooting itself. Is anyone else having issues with it?
Running the same overclock with no problems. Also I believe the sbf for. 320 will fix both. 320 and. 340. Just after sbf update up if you want.
I have a question, if I have a nanoid backup and I install a custom rom, can I simply restore a nanoid backup to revert me back to the stock image before I installed rom or is there another app required to do this? I have restored from adding themes but I do not know if the roms requires a different process?
Always make a backup of a stock image. Once on new update. Make a backup. Then you can rom and theme all you want. Go back to that stock image when needed. Once you update don't flash back to old ones. If on 2.2.1 don't flash a 2.2 backup.
Good Question. The answer is YES! you will revert back to STOCK if you restore your STOCK nanoid backup. One of the beauty's of Android.
If you used TBH SYTEM ONLY SBF
Ok guys just when you thought it was safe to go back in the waters.....
TBH has put up some patches to their 340 sbf system file.
Applying these patches will put you up to the latest and greatest.
These are ONLY for those that flashed the .340 SBF SYSTEM ONLY FILE.
I have flashed all three of these, no problems just one little hiccup.
You will NEED to reactivate your phone, A SIMPLE PROCESS.
dial *228 and press 1 when prompted. DONE
TBH Patches: 2.3.340-System, Baseband, 2.3.340-Kernel, Bootloader
Dave7
