Apex vs Nova
Did you read the comments? Fourth comment in, someone said the author was asked on g+ and he said Nova is being continued.
One guy said it's being ended, one says it will continue. Not sure which to believe. I sure hope he continues to support it.
I would be most inclined to believe the actual app author, and not some random person on Reddit. Since these comments regarding the future of Nova supposedly happened on Google+ you can probably find what the app author actually said if you have the inclination to look. It doesn't bother me enough right now to look, but I don't think it is a good idea to continue spreading this rumour unless you have evidence it is actually more than a rumour.
I would be must inclined to believe the actual app author, and not some random person on Reddit. Since these comments regarding the future of Nova supposedly happened on Google+ you can probably find what the app author actually said if you have the inclination to look. It doesn't bother me enough right now to look, but I don't think it is a good idea to continue spreading this rumour unless you have evidence it is actually more than a rumour.
LOL, I wasn't trying to spread a rumor. I just posted a link that I saw 1 time. I didn't see that ninja edit the first time I read the thread.
Fair enough, I didn't mean to imply you were intentionally trying to spread a rumour.
I've used the pro version of both launchers for a couple of years. While they both have small differing advantages, I find myself using Apex a little more. Overall I prefer the more polished interface, and currently I find it supports Chronus Widget much better than Nova does. The default layout seems slightly more balanced on Apex too.
I like the multi-app select when setting up Nova way better than Apex's labourious one by one approach, but fortunately you only have to do this the once. Nova also has an extra 3 or 4 transitions.
I haven't noticed any real difference in speed, memory consumption, or battery drain between the two.
Great post, thanks.
I just bought apex pro today to get the uncount reads on missed calls and texts.
So what exactly nova prime is better than apex pro?
All you had to do is download a client for Nova to get the unread badges.
Nova updated yesterday :) Updates look great and the gestures are working again properly with the notification bar, yea! :)
Deinenxo
