APN Changed.
Yes of course it works. I have an AT&T data sim that I sometimes use for my iPhone 4S. I also have a T-Mobile data sim that I use in my Nexus 7 that will work in my Nexus 4 and iPhone 4s.
I tinkered with the settings a bit and found this to work.
APN: phone
MMSC: http://mmsc.mobile.att.net
MMS proxy: proxy.mobile.att.net
MMS port: 80
MCC: 310
MNC: 410
APN type: default,supl,mms,hipri
APN protocol: IPv4
APN roaming protocol: IPv4
hope i typed all that right (proof reading after midnight isn't always as accurate), and hope this helps!
APN: phone
MMS port: 80
MCC: 310
MNC: 410
APN protocol: IPv4
APN on the Nexuxs 7 is simply broadband. None of the other settings are set other than the APN name as broadband.
My iPad is the same way for AT&T, APN is set as broadband and the other settings are blank. This allows LTE on my iPad.
See i knew i'd screw that up somehow... My reply was meant to be earlier in the conversation when you were still talking about the AT&T Nexus 4 APN settings
Yes. I used the broadband APN for my Nexus 4 also. Worked great using the AT&T data sim.
Haris18
