[App][4.0+] CPU Hardware and System Infos
Hello,
I updated a new version of CPU Hardware System Info with an update improving generation of the PDF report.
Give it a try and send me your feedbacks.
Thanks.
Sylvain
Hello,
I updated CPU Hardware and System Info to fix a problem with CPU Temperature that affected just some devices.
It seems also that there is a problem with Sony Xperia to display CPU Temperature. If someone here has a Sony Xperia, can he check if CPU Temperature is displayed ?
Thanks for your help.
Sylvain
Hello,
I updated CPU Hardware & System Info in version 3.0 on the Google Play Store. The update brings you the following changes :
* Permissions management
* Updating the list of devices recognized
* Kernel Architecture is now well displayed
* CPU Load is supported up to 8 cores
The application is available on the Google Play Store in two versions :
- Free supported by Ads : https://play.google.com/store/apps/details?id=com.ssaurel.cpuhardwareinfos
- Paid with no Ads : https://play.google.com/store/apps/details?id=com.ssaurel.cpuhardwareinfos.pro
Don't hesitate to give a try to this new version and give me your feedback.
Thanks.
Sylvain
maryhurst515
