[APP] AeroConn - network speed and signal monitoring
asmok
7
AeroConn is an easy way to monitor and count your GSM or WIFI network usage.
Features:
  • home screen widget showing the signal level,
  • counters on the status bar (current transfer),
  • traffic monitor,
  • shows your IP address and host name,
  • data transmission scheduler, (need root on android 5 and above)
Download:
Google Play: https://play.google.com/store/apps/details?id=com.shilimobi.aeroconn
Amazon Appstore: Amazon.com: AeroConn - network signal and speed monitoring: Appstore for Android
Slide Me: AeroConn | SlideME
Description:
WIDGET:
Provides information about the currently used network. Showing: network type, network name, signal strength (dBm)
COUNTERS IN THE STATUS BAR:
Displays current download or upload speed directly on status bar.
TRAFFIC MONITOR:
This screen showing Your IP Address and Hostname, amount of download and upload data, current network speed and signal level. The graph shows the transfers of the last two minutes.
DATA TRANSMISSION SCHEDULER: (need root on android 5 and above)
Disables data transmission when the screen is blank. Optionally, can turn every several minutes to retrieve the message. For easy control of transmission saving app contains a widget that switch this option.
Other: Support for Aero2 network in Poland
Screenshots:
I hope you like it.
heritagevines30
