dijn Member Sep 29, 2018 9 0 0 Mar 4, 2021 #1 So there's an issue with rn 9 pro max where app icons are placing themselves on top of other icons and I'm unable to form app groups on the screen
mustang7757 Admin Moderator Moderator Feb 6, 2017 98,813 15,421 113 Mar 4, 2021 #2 Look at your font size and are you using a 3rd party launcher?
B. Diddy Senior Ambassador Moderator Mar 9, 2012 169,618 11,037 113 Mar 4, 2021 #3 Does that persist if you change wallpapers? Are you sure you're not using a wallpaper that's actually a screenshot of your homescreen?
dijn Member Sep 29, 2018 9 0 0 Mar 5, 2021 #4 B. Diddy said: Does that persist if you change wallpapers? Are you sure you're not using a wallpaper that's actually a screenshot of your homescreen? Click to expand... Nope absolutely not. New apps just appear on the home screen randomly placing themselves anywhere
B. Diddy Senior Ambassador Moderator Mar 9, 2012 169,618 11,037 113 Mar 5, 2021 #5 This is the stock launcher, and not a 3rd party one, right? Does this persist after a reboot? Try booting into Safe Mode: https://www.hardreset.info/devices/xiaomi/xiaomi-redmi-note-9-pro/safe-mode/
