[App] Multiwindow Dialer, call with your samsung in multiwindow mode!
Update:
- Update samsung sdk;
- Improve gestures: swipe from right to left clear the number if the textfield is filled, open call log if not and swipe from left to right open the contact list if textfield is empty, send sms to the typed number if not;
- Type a number and touch it for open edit-add contact interace;
- Minor layout improvements;
- Various bug fixes.
Free version (with advertising): https://forums.androidcentral.com/e...?id=simone.cascino.multidialer&token=K-XlGfSf
Plus version (without advertising and 28+ themes): https://forums.androidcentral.com/e...simone.cascino.multidialerplus&token=uN3xnjBB
Update:
- Added air gestures! Is a samsung feature, make gesures without touching the screen, moving your hand in front of frontal camera. Attention: may not work on galaxy s4, because an hardware issue (is explained in the samsung developers documentation). You must enable this feature through the options menu (other options);
- Improve gestures: perform a swipe from bottom to top, if the textfield is filled you can copy the number in the clipboard;
- Various layout improvements.
Free version (with advertising): https://forums.androidcentral.com/e...?id=simone.cascino.multidialer&token=nHqeUhgP
Plus version (without advertising and 28+ themes): https://forums.androidcentral.com/e...simone.cascino.multidialerplus&token=ZOuCp-co
Thanks!
Update:
- Filter call log for incoming, missed, outgoing and rejected calls;
- Delete single item from call log;
- Selective call log deletion: you can choose to delete incoming, outgoing, missed, rejected or the entire call log;
- Added intent filter for open this app from other apps (and choose as default dialer);
- Layout improvements.
Free version (with advertising): https://forums.androidcentral.com/e...?id=simone.cascino.multidialer&token=iRUJvoDO
Plus version (without advertising and 28+ themes): https://forums.androidcentral.com/e...simone.cascino.multidialerplus&token=BqMXlpH5
Does your app support video call? Either way, this is a really nice app.
Done! Thanks for your suggestion, and sorry for the time!
Update:
- Sort contacts by surname (check the "other options" menu);
- Perform videocall with a long click on the sms button. ATTENTION: this function work if your phone supports videocall via sim card. It depends from your operator and your phone. For example: in note 3, note 2, s5, s2, s3, s4 mini works, but in nexus 5 and lg g2, with the same sim card, doesn't work, starts a normal call. In this case, if you want perform a videocall, you must use an app like skype, that use internet.
- Added 4 gradient themes in the plus version.
Free version (with advertising): https://forums.androidcentral.com/e...?id=simone.cascino.multidialer&token=Ul5xewXC
plus version (without advertising and 32+ themes): https://forums.androidcentral.com/e...simone.cascino.multidialerplus&token=i9miD9ZA
Update
- Added alphabetic layout to the contacts list;
- Improve contact badge layout (long click on a contact);
- Added labels to the numbers;
- Bug fixes and optimizations;
- Now advertising (in the free version) mark only when you close the app or rotate the screen.
Free version (with advertising): https://forums.androidcentral.com/e...?id=simone.cascino.multidialer&token=eC1Kx-pW
Plus version (without advertising and 32+ themes): https://forums.androidcentral.com/e...simone.cascino.multidialerplus&token=emn90YEqScreen.jpgScreen2.jpg
Update:
- Widgets in the notification bar (3 in plus, 1 in free! Check the options menu;
- Long click on asterisk for starred in android grid;
- Long click on hash to change audio settings (vibration or normal mode);
- Added 2 new actions for gestures customization (starred in android and audio settings control), only for plus.
Free version (with advertising): https://forums.androidcentral.com/e...?id=simone.cascino.multidialer&token=yRJK9SGv
Plus version (without advertising, with 32+ themes, customizable gestures and 3 widgets in notification): https://forums.androidcentral.com/e...simone.cascino.multidialerplus&token=9rVB6e-1
Screenshot_2014-11-03-17-11-04 - Copia.jpgScreenshot_2014-11-03-17-11-42 - Copia.jpgScreenshot_2014-11-03-17-12-23 - Copia.jpg
nice work!I'll definitely try it! thanks for what you did guys!
Thanks to you for appreciation!
Update:
- Added homescreen widget with starred in android list.
Free version (with advertising): https://forums.androidcentral.com/e...?id=simone.cascino.multidialer&token=RrD1LY9O
Plus version (without advertising, with 3 notification widget, customizable gestures, homescreen dialer widget and 32+ themes): https://forums.androidcentral.com/e...simone.cascino.multidialerplus&token=aeocz1sf
Huge update:
- Exclude sim contacts from the contact list;
- Added 3 themes (2 unlockables with facebook for the free version);
- Support for translucent statusbar (android 4.4+);
- Added animation in the popup letter preview in the contact list;
- Improve scrolling of the contact and suggestions list;
- Restore state of all popups when the screen is rotating;
- Improve themes popup layout, changelog popup layout and log list layout;
- Added new icons for log list;
- Added elevation in popup letter preview and top bar (android 5.0+).
Free version: https://forums.androidcentral.com/e...?id=simone.cascino.multidialer&token=d1SCtz9U
Plus version (without advertising, with customizable gestures, homescreen dialer widget, 3 notification widgets and 36+ themes): https://forums.androidcentral.com/e...simone.cascino.multidialerplus&token=00FGgO9X
Screenshot_2015-01-15-15-10-57.jpgScreenshot_2015-01-15-15-07-54.jpgScreenshot_2015-01-15-15-10-22.jpg
benjifred645
