[App] Multiwindow Dialer, call with your samsung in multiwindow mode!
- Update contact list and log list with a pull gesture;
- Added possibility to change numbers size (check the other options, adviced 25sp);
- Improve contacts list and suggestions images;
- Added material style for some widgets (requires android 5.0 lollipop or more);
- Great UI improvements;
- Click on the numberfield when is empty for paste a previous copied number;
- In call suggestions, click on the picture for display the contact preview;
- In the contact preview, click on the white titlebar for see the contact detail view;
- Bug fix.
Free version: https://forums.androidcentral.com/e...?id=simone.cascino.multidialer&token=8Grvm2is
Plus version (with more themes, more widgets, customizable gestures and no ads): https://forums.androidcentral.com/e...simone.cascino.multidialerplus&token=uyqoywEp
Screenshot_2015-03-17-12-34-31.pngScreenshot_2015-03-17-12-35-46.jpgScreenshot_2015-03-17-12-30-23.jpgScreenshot_2015-03-17-12-30-11.jpgScreenshot_2015-03-17-12-29-53.jpg
Update:
- Touchless control (for galaxy note with the spen and some other samsung device with finger hovering support, like galaxy s5)! Check the new menu (air options) and enable airview/touchless control. You'll can use some core functionality (like type numbers) without touching the screen;
- Dismiss popups with airgestures (on the left/right) if you have air gestures enabled;
- Bug fix.
Free version: https://forums.androidcentral.com/e...?id=simone.cascino.multidialer&token=x29KwCyA
Plus version (with customizable gestures, more widget, more themes and no ads): https://forums.androidcentral.com/e...simone.cascino.multidialerplus&token=-tL97GsK
papicef
