April Update-US/International
I've been there before...
Hopefully soon for you! 🤞
Thanks. I just hope my phones not in limbo. It got OTAs since but I have run into in the past having to manually flash th4nfirst update after converting from U to U1 back to U.
I actually prefer, at least T-Mobiles, carrier versions of Samsung hence the back and forth.
Edit: Reread above and its confusing. Previous phones I ODIN flashed unlocked (U1) and back to carrier (U). OTAs didn't arrive until I manually flashed the first/ next released update manually.
So hopefully that's not what's happening here.
/mylifestory
Reactions: BerryBubbles
Awww I knew features would be axed. First thing missing already is the vivid slider.
Also for those bothered by it (The Gesture Pill), you need GoodLock (NavStar) and turn on "Enable extra gesture settings" to get the option back in System settings under Display/Navbar
Thanks for this reminder. I couldn't recall how to disable the gesture hint until I read your post.
Good they kept the charge cap drop from 85 to 80.
Slowly trying to remember what else was on the S24U that's still here and what's gone.
Chime in if anyone else finds or knows of anything.
The Vivid slider is under Advanced Settings now.
Settings -> Display -> Screen mode -> Advanced settings
That's different. Those are individual fine tuning of RHB spectrums. S24 got an actual balance slider for intensity of vivid.
Mods: These are "villageidiots" own words. He's a bit slow.
You really are always about 3 topics behind at all times. I said that slider is missing but had it on the S24 Ultra.
The Advanced Option only takes to the Whitebalance/RGB sliders...
Ummm... You're the one that said the Vivid bar is gone. I'm not sure where you said it wasn't.
Charlotte Breece
