Archived: [ROM[2.3.7]LeWa OS! 3.2.2
I would like the seven theme but I can't download off the theme market because it says its already on my phone, however I can't find it on it. Is there a way to download it online and install on phone?
It looks and works well. Looks like we need to find a new work around for 3g though because the option to check cdma0 isn't there.
I was using this ROM for a short time earlier and it had seemed as though 3g was working for me with no problems.
Sent from my LG-VM670 using Tapatalk 2 Beta-2
I'll check. Still dealing with the iPhone. I'm sorry.
If you find another LeWa MDPI phone, give me link and I will post. :)
Go in to settings ,mobile networks,access points names,virgin mobile us, select.. scrol down to APN type and erase mms , them save it by pressing the menu,save
Once done select virgin mobile us again, click the home bottom and you should see 3g
Edit, or you could create a new APN , once in access points names, click the menu , and create a new APN name it What ever you want , then under it put a 1 and save it.
I have good news !! Well half MMS IS WORKING but only 50% you can only send MMS. Camera takes pics and videos!! Music still force close , don't forget to turn the volume up!!
Machetaseo
