Archived: [ROM[2.3.7]LeWa OS! 3.2.2
Re: [ROM][ALPHA][2.3.7]LeWa OS!
Didn't see this mentioned (sorry if it was) but camera doesn't work. Just freezes
Gonna grab build properties from iho n put it into lewa...see if 3g gets fixed...going rogue here lol....will edit build propertied to match most of the original properties...just saying
Iv'e tried that and I didn't get any results. let me know if you get it to work. maybe something magical will happen! lol
Very fast I mean Fast rom, only thing was the 3g. :( I could still make calls... but no internet (ulness I use wifi) can't wait till the 3g fix... thanks!!!!!!!!
Its defiantly not the build.prop. iv'e tried 3 different IHO ones and even the one one from the miui and isc ports no 3g at all. but the build.prop that comes with this LeWa port works perfectly fine on my brother OV with the most recent backside rom. this leads me to believe its Not the build.prop but something deeper.
Reactions: Badboytoast
Unless something is interfering maybe?
Could this be ported using Jerry backside, instead of mirage maybe this could fix the 3g issue, since you say this build.prob works on your brothers backside... or something like that :D:cool:
I'll try that
Sent from my Amazon Kindle Fire using Tapatalk
To fix 3G try looking at the apn-congfigs.xml and compare it to one from an iho rom, if the numbers next to virgin don't match, I think 3G will have problems. Maybe I'll look at this when I have time.
Sent from my Optimistic Optimus
Yup...failed lol...still no 3g...
I didn't touch the apns-config.xml
It's exactly the same as the IHO ROM. Let me try and port it with Jerry's ROM
Well anthonycr was right, and it seems that it is the apns-configs.xml, yet I'm not really seeing what I should do with it yet, I've tried the MIUI one in there, and the CM9 one...
Does it match the one for virgin mobile? i tried swapping the apns-config.xml this morning with the iho one and still got no results.
Nope, went and tried it and no 3g. Which, if it helps, means that the probelm isn't in the kernel but somewhere higher up in Android.
gruptysh
