monsieurms
- Sep 30, 2011
- 1,603
- 143
- 63
It should slow down now. I've went through all the episodes of trailer park boys
Well, there is also this wi-fi.... Really helps when streaming.
Well, there is also this wi-fi.... Really helps when streaming.![]()
I am on WiFi at home,work, and church. My wife, daughters and myself barely use 4GB a month. We have 13GB to share.
Sent from my GNote4 using Tapatalk!
Not to me I know I have it if I need it. I can use for when I have to use Foxfi.Sounds like a waste of money for that much then.
Not for me -- at work the wifi is 1 Mbps .. streaming is non-existent on it.
Yes I have wifi at work but my work tracks wifi usage. Personally I don't want my employer to know what sites I am visiting. At home, I have a Verizon wireless 4GLTE broadband router with voice, so using wifi or 4GLTE still uses "mobile" data. I had twc 15/1 before but they are very slow at peak times (sometimes sub 1mbps down) .The Verizon 4GLTE broadband router is faster especially during peak. No problems with streaming in fHD. On twc, a single hd (not fHD) stream would stutter badly sometimes.To the people that average more than 10 Gb if data a week... Do you all not have wifi at work and home?
I believe you hold down on the home screen like you're adding a widget. Then click settings. You should find something about flip board I believe.How can I disable the flipboard? If I go into app mgr. I can clear the cache but the Uninstall is grayed out?
I installed Nova and uninstalled touch wiz so if this isn't the way my bad. I think I remembered correctly though. Lol
So I'm gathering from the 18GB dedicated to just one app that part of your job responsibilities is to watch TV on the Xfinity TV Go app?![]()
I, too, noticed my data usage has gone up & I've mostly gone to Google Play to download apps & ringtones. I'm on Sprint & have never gone over 2 gigs, according to the rep when I got the Note4, so she lowered the data usage to 2 gigs to lower my monthly bill; said I was overpaying unnecessarily. For the 4 yrs. I've been w/Sprint I had always been on the Unlimited Plan.
So after reading these posts, my question is: Am I supposed to always connect to wi-fi when at home and usual places I go to where it is available? I have always unchecked it when it turned on by itself. I always thought I should be using Mobile Data.
In Data Usage I have Mobile Data checked and Limit Mobile Data Usage unchecked. Please advise me on the correct way I should be connecting so as not to go over my data usage and end up paying for the overage.
Thanks in advance!
