- Dec 2, 2011
- 496
- 0
- 0
The iras scan is Infrared I believe so maybe there's a simple way to get Infrared remote control working again..?
Not sure what either of your posts have to do with this thread about the iris scanner possibly being infrared.I Need Google keyboard
Has it on iOS this driving me nuts with typos
Infrared isn't visible to the naked eye so not sure the iris scan is actually infrared. Even if it was, the focal point of it is so short, I wouldn't think it would have enough range to operate anything at normal TV viewing distances. Think about it, it has to be 8 - 10 inches away to even read your iris.
As mentioned above, it wouldn't be very practical since you'd have to face the phone screen at the TV while trying to press buttons.
I use the edge light for phone cslls
How, may I ask, do you get edge lighting to work with incoming phone calls? The Phone app is not one of the app choices to turn on for edge lighting, at least on my Verizon Note 8.
