AT&T Galaxy SIII 4.3 Update Likes/Issues
Re: AT&T Galaxy S3 4.3 Update Likes/Issues
are you getting issues with the app to sd function, like, when I supposedly move apps to sd the miscellaneous area fills up and nothing shows up on the external sd?
Can someone point me to the change log of this update? Thanks! Updating now .=-O
Sent from my Nexus 7 using Tapatalk 4
Still can't get my FoxFi to work.... Anyone else figure it out yet, or is this a bug?
Sent from my SAMSUNG-SGH-I747 using AC Forums mobile app
Downloaded today and working great. Have been trying to find how to do away with notification bar on Lock screen. Any ideas would be appreciated.
I got the update today, and made the Downloads fix described here. So far I like it. I had to correct my notification sounds for texts and emails, they reverted to something else, but it seems to be working quite well.
It's not a bug.. AT&T is trying to stop us from using FoxFi or PDANet..
Thankfully the "Bluetooth Mode" of the full PDANet+ still seems to work for me. It is not nearly as fast or convenient as the wifi mode, but at least I can still get my tablet online while on the road.
Sometimes I really hate AT&T...
Sent from my Sero 7 Pro using Tapatalk 4
Maildroid seems to be lagging severely. If I have issues with push email this update may have to go. Is there a mail app that handles push well on 4.3?
Response I got from foxfi regarding a fix for 4.3
Hi
We are currently working on a fix in our future updates. I do not have an exact date yet.
Thanks, June Fabrics PDA Software Support June Fabrics PDA Technology Group
Also this regarding alternate I haven't tried:
> > > Hi > > > > If your carrier blocks your tether usage in WiFi mode, try to use USB > > mode instead in PdaNet+ and set Hide Tether Usage to Level I.
> > > > Thanks, > > June Fabrics PDA Software Support > > June Fabrics PDA Technology Group.
I just updated and the edit function for contacts will not update when adding a group, ie family friends etc. When I try to add family,etc I get the following message "Unfortunately, Contacts has stopped." Anyone else ran accross this and have figured out to make it work? Everything else seems to be working Ok.:cool:
So I've downloaded the file multiple times and even did a factory reset and attempted to unroot, but after downloading the huge file my phone restarts and gets to 25% installed and fails. Anybody else have this problem?
Why am I not seeing an option to change the lock screen shortcuts? I think I've looked everywhere. Can someone check? Thanks!
Yes...I have the exact same issue. Rooted stock TW here. I'm going to unroot based on instructions here: How to Unroot AT&T Galaxy S3 SGH-I747! and try again over the weekend.
I've uninstalled and re-installed Hangouts and will test it today.
I was using Maildroid until I just did a factory reset. Before I was using it on my 4.3 updated S3. I noticed it was having issues. Have not tried it on clean install. Maildroid is really the best one I've found. There is a support page and the dev has readily responded to me in the past.
Was having the same problem with download notifications. Clearing out the Downloads app lists appears to have fixed that.
I was also having a problem with a song that would start playing randomly. There was no rhyme or reason as to when it would happen. On or off a charger, making a call, listening to other music, just sitting there untouched. NOTHING. Additionally, it was a song that I did not even recognize. Swiping down on the screen would stop it from playing. I even restarted the phone and let it sit untouched. When the song started playing, I went to see what/which music playing was being used and there were none bring used.
Last night I just removed and reinstalled all my music and netcasts (kept on the external card) and it has now been over 12 hours with no random playing of this one song.
just got the 4.3 update. I like it but, my s3 is on straighttalk and every time I unlock my phone it pops up with a message from at&t contacts saying it will sync when I am connected to the mobile network. Anyone know how to stop this??? TY
oops just figured it out... if anyone else has this issue, I went to my contact, his the menu button then settings, then at&t address book then click stop sync....
where do I find the download applications. I went into my files and cleared downloads but it is still happening
BarishYadav
